Parks
  1. Parks changed their profile photo
  2. I have an 02 cummins 4x4. Pulled the codes and had p1698 p1689 p0237. Replaced the vp44 and still had the codes. Cleared the codes out took the truck for a drive and hooked the scanner back to the truck and it will not read codes so I done the key trick and am getting p1694 p1693 p1687 and p0237. Truck starts up fine and drives but it has no power has the CEL ABS and BRAKE light on the dash. Got to looking under the hood and seen that the previous owner had a wire on the harness to the pcm tapped and grounded. Took that wire off and nothing changed. I don't know what to do next!
  3. Thanks for all the opinions! I'll let ya know what comes of it
  4. No, it has a 4" straight pipe and I believe it used to have an edge tuner. I bought it and found an edge owners manual in the glove box
  5. I have an 02 cummins ext cab short bed 4x4 with an auto. Truck was foggy and lost all power. Had codes P1698 P1689 P0237 which myself and mechanic buddy thought it was a bad vp44. So we replaced it with a new one from thouroughbred. Anyways he put it on and all the codes are still there and nothing has changed. I don't know what to do next!! Also have an airdog raptor and at WOT it still has 8psi
