Hilbily4x4
  1. I have a '99 24-valve Cummins that recently has been having starting issues. It was taking a long time cranking to start but I got my batteries tested and one was replaced under warranty. I also cleaned the terminals at that time and it was back to starting right up usually on the second or third crank. Then about 2 or 3 weeks ago I jumped in and turned the key to get nothing from the starter at all. I popped the hood and kinda felt the main wires and tapped on the starter. Then my neighbor came and turned the key while I looked under the hood and boom, started right up. Then it was fine until two days ago I drove to the gas station and on the way there my check engine light came on. I turned off the truck went inside and when I came back out it would crank but not start. I left to get a code reader and came back about an hour and a half later and the code reader said 1 ECM code and 2 OBDII codes, but they were all P0336. I cleared the codes and the truck started (weakly, but the batteries were drawn down at this point). Then I drove it home, the check engine light came back so I rechecked it, same code P0336, cleared it and restarted the truck and just let it idle for like 15 minutes. The check engine light did not come back on. Then today I got in and the starter sounded really weak, like not getting enough juice, but it did start and got me to work. Now, I got in to go home and it sounded like the starter was barely getting enough power so I got a coworker to give me a jump, but when I turned my key with the jumper cables hooked up it got dash lights only, the starter wasn't even turning at all. I tapped on it but that didn't help. The starter is only 2-3 years old. I'm thinking maybe bad wiring going to the starter? Mostly thinking this because when it works, it starts right up, but intermittently it will crank for a while. Please help, I just put a new nv4500 and valair clutch in this truck and starting to regret it already. I'm afraid of needing ECM or VP because I cannot afford it at this time and this is my only vehicle.
