Draginjet
  1. Maybe someone with a 01 cummins could post a pic above and in front of the starter that shows this bk/wh wire and where it connects?
  2. We are installing a replacement 5.9 Cummins engine in my sons 2001 Dodge Ram 2500. My question is on the engine wire harness just in front of the starter there is a Black wire with a yellow stripe, BK/YL, where do I connect this wire? Thank you for any help. Additionally. I just looked at the harness that came with the replacement engine and that same wire sticks out of the larger wire bundle about 6" which is same as on his truck but this wire is Black with White (BK/WH) stripe. I tried to clean up the one on his truck thinking maybe it's stained but it still show yellow stripe. Is this a ground that goes to the bracket under the fuel filter?
