zimmerjo61
Everything posted by zimmerjo61
  1. I installed gauges into my 2001 Auto. I had fuel pressure and pyro before. I added boost. Checked all the gauges for light up prior to fully mounting the pod. They all worked. Installed the pod and hooked up all the gauges. No lights for gauges and no illumination lights in dash. Parking lights also wont turn on with headlight switch. Turn signals, head lights, dome lights, blower motor, and radio all work. I went to start the truck, it fired then died. I have good fuel pressure to VP. I checked for codes and none. I checked fuses and all looked good. Batteries were a little low due to cold weather so they are on charger. I will crack lines at injectors next to see if getting fuel. Could these be related or just coincidence? Need some advice on things to check.
