blkruby
Everything posted by blkruby
  1. i think the reasoning for low pop pressure is for timing on the dragon flow pump at the higher pop it could hydro lock the pump. but the truck idles great and climbs threw the rpm smoothly
  2. 6x.018 and a dragon flow pump and the injector are set a 260 bar
  3. so is there and thing i can do in the tune to alleviate this? also is there and thing i can do in the tune to help with smoke other than the boost level fueling
  4. ok, so what would cause the loping i have now under 10% throttle
  5. @Me78569 @Quadzilla Powerso I've got a couple questions, First can you lower boost level fueling any more there 50%? and second question is once i set my daily tune anything under 10% throttle the truck will lope, once pass 10% it runs fine and it will idle fine this is only on lvls 2 and up lvl 1 it is fine
  6. I’ve just got the truck running and still have the edge comp box installed and it is a smoky mess so I’m looking to get a daily tune that I can work off of. The mods to the truck are a 6.7 188/220cam 6x.018 injectors dragon flow pump and sxe480 and a sxe364.5
  7. I did not go with the 4K just because of the drivability. Correct me if I’m wrong, I can always switch to 4K but once I have it I can’t go back without a board change
  8. Yes I can the motor is a 2010 6.7 that has been girdled and carrilo rods 20 over pistons Hamilton cam pushrods 6.7 stage two head with billet intake, and Im running the vp44 injection system still. The motor is a year old I was running a Hotrod pump and 150 injectors and a Garrett stage two second gen turbo kit on it. Over the winter I did the compounds and the dragon flow pump and DDP injectors still waiting on the pump and injectors. I purchased the quadzilla this year and its still in the box cause I was gonna get it running on the edge and then switch over and try tuning with the quad. Any help you could give me would be great and if you have more questions on the swap please ask
  9. Came here to get some help with tuning my truck with the quadzilla. The roads here are still covered in salt so shes still hiding in the garage and also waiting for parts to arrive
