Thehomie103
  1. P0230 is the transfer pump out of range that's when it drops voltage to 0 P1698 idk what this one's for but I'll find out P1694 same P1693 same
  2. Has problems when it's heated up or sometimes out of no where throttle body sensor goes to zero voltage randomly but then picks back up after hitting the gas a couple times also shuts off driving down the road when it's warmed up but starts back up right away lift pump is new so are the lines and the tps sensor is new also.I checked the fuel pressure and it's stays the same when driving. The rpms start jumping from 0 back to how much rpms you have back down to 0 then the truck dies but starts back up but then starts happening again
