Strokin and pokin
  1. Strokin and pokin changed their profile photo
  2. When you go to default profile you can go from 0 to 10 power levels, so is that the same tunes at v1?? And when you are using your custom tunes what do the 0 to 5 power levels change??
  3. You are right I was using (V2 quadzilla only), I just switched it to (V2 dodge 1998 2002) so I should be good. I don’t know how to change the levels, all I see is to change power levels and the lowest it goes is 6
  4. On my phone display it has a little box that reads out wiretap percentage and I get 0% I looked in my sensor warning and my coolant was at 220, so I changed it to 160, also what is the power control?
  5. So I installed a quadzilla Adrenalin with V2 tuning on my truck about 2 months ago, and at first I put a scotch lock on the tap wire and I went out and drove it and the display on my phone says 0 pump tap. So I thought that was odd and I played around with my tuning to make sure it would go on with so much PSI and still no pump tap. Finally today I desided to solder the wires together and went for a drive and still no pump tap. Please help.
