wagntagn
  1. Good point!the G56 as to be exactly the same specs for mounting did anybody do the install?
  2. I heard they’re are to find in Canada now co vid is almost over maybe I’ll shop across the border
  3. Yep the guy told me it was a wreck,so in 96 the tranny shaft wasn’t very big maybe I’m better to find something newer & less K I’m in no rush my 47re as been rebuilt with a triple disc 10K ago just want to do the switch for kicks
  4. The scrap yard guy told me he as a 96 dually he’ll strip it down so I’ll get the tranny,transfer case,drive shafts,cross members,clutch & pedals,stick shift for $3500. that’s Canadian his truck as 512K that sounds ok of a deal?
  5. Is the 4500 5 speed a good pick for the switch ?
  6. Nice rig!Your turbo is a size up to the HX 35W and you run the 100 hp injectors what size of lift pump and what’s your tire size?Maybe I should go your way!!
  7. When doing the switch I’m probably better to do the studs at the same time?
  8. I’ll replace the exhaust manifold it as a few airline cracks but no leaks,checked online they have the high flow is it worth it what’s a good make?
  9. Yep running on the Smarty,the Tranny fresh rebuilt triple disc pulling the fifth wheel runs cool no problem should be good to handle the boat.One thing hopefully the ddrp02 will keep up to the injectors and turbo I ran 1/2” lines from bottom of tank to the ddrp02 if it doesn’t keep up I’ll switch the ddrp02 for something higher flow we’ll see.
  10. I’m not looking for too many HP I’m towing a 30’ fifth wheel which the truck can handle but I want to pull my 18’ Lund boat behind the fifth wheel which weighs 3000 lbs so I need xtra hp
  11. K thanks I’ll go with Bosch.If I keep my HY with the J hook at 32 psi it would be about the same as the HX?
  12. I have a boost gauge with my HY I get 20 psi max.to get 32 psi I probably need the J hook .I can get a deal $580. Canadian for 6 injectors the make diesel USA??Any good?
  13. I have the smarty I don’t think that one as the boost cooler? I meant”fooler”.with the elbow how high will the boost pressure go?
