gordfarr
  1. Sorry about your roads out there mine have been paved for about 5 years now. I think Ill go with BHAF when I get the LOOT thanks.
  2. They are not locked up. They will not apply. --- Update to the previous post... Probley corroded up I guess. Will try the ones off my 2000 if they aren't fouled up. I just havent run into this problem before.
  3. Not like that at all. My emergance brake cables are frozen. Not one but both the one on the left and right side. I got under neith the truck and at the part that connects the cable from the foot peddle to the middle of the truck was all right. I tryed that unhooked from the rest. The cables from the middle of the truck to the drums where locked up would not move. I took them out put one end in a vice and pulled on the other end and would not move. I guess I need new brake cables from the drums to the middle of the truck?
  4. I was just wondering if one was better than the other. I clean mine more than I change oil. LOL
  5. Let me run this by you. My emergance brake cables are frozen up would that have any thing to do with it.I am sorry forgot to mention that.
  6. Should I change to BHAF? I just read a post that said K&N were junk. I bought the truck with it on there. Not a puller or racer just use it for work. I do pull loads ,GCVW about 35000. Just put fuel press. gauge on so empty I have 16#, and WOT better than 14#. Am looking to put more gauges on. I did go across the scale today with a load of wood that weighted GCVW 42100#, that was my truck & trailer. Hauled it down the road pretty good never cut the edge on and was up to 55 in about a mile. I M INPRESSED.
  7. My speedo still works so am guessing the rear sensor is still good, not a fuse prob., so I am going to take the sensors off the front of my ,wrecked 2000 3500 with auto, parts truck for me, and try them on my truck. Does anyone fore see a problem? Thanks
  8. Sorry I am new on here but have been on other sites that told me things that weren't exactly right. Just if someone is wondering the VP off a 2000 (so) with auto trans. will work on a 2001 (ho) with 6 speed. I made the switch about 500 Miles ago at first I thought it was the IP and swaped the pumps, it turned out to be the APPS. The pump off the 2000 (so) works just fine on the 2001 (ho). '
