ScarletHO
  1. I am told I need to replace the chain in my transfer case. I am also told that it is fairly easy to do. Do you have any suggestion or writeups on how to replace the chain??
  2. My truck is a 2002 2500 HO NON sport truck. For Christmas my wife bought me some of the projector lights (also called angel eye headlights). Before installing the lights I bought the heavy duty wire harness from LMC truck. The one with the relays and pulls its power from the battery. I have installed this harness already. This headlight kit converts the single bulb 9004 to an H1/9005 setup (like the sport model). To make the system work properly, the instructions say to swap the high beam and ground pins in the headlight harness plug. My question is, there are 3 wires in the harness but, which wires I need to swap to make this lights perform properly. Also.. what is the trick to getting the wires out of the connector to swap them.Thanks in advance for the help!!Greg
