eaglesilas
  1. thanks,found one an eabay for 45,
  2. Replaced my broken manuel Mirrors with heated/electric Mirrors. The electric works fine , how works the heated part? The plugs was already in the door, the switch I bought on ebay. 2001 -3500 Dually
  3. My head light won't shut off , only head lights not the tail light or cab lights, and my high beam staying on, and the blue light comes on in the inside. I have to pull the fuse to shut them off but only one fuse not both.
  4. I think found the short, my side maker lights on the dually fender on the left side . lights are working now for 2weeks.
  5. that's the writing on the cover park lamp
  6. thank no spare tire, It's the park lamp fuse
  7. I have no tail lights, dash lights, marker lights. Only my headlights are working .The fuse blows after 1 minute I turn the lights on. Some advice ,where to start to check
  8. Thanks Guys , the switch was bad.
  9. Was pumping gas and my lights shut off. Turned the switch off and on, no lights only headlights.no tail, no side marker , no cluster lights , inside lights working . checked fuses, all good. Turn and brake lights working.
  10. Disconnected the heater core for now, need a new one. was not the resister, was the blower motor. put a new one in. now my A/C works. Thanks guys.
  11. My blower works only in the morning , when I drive 10-15 miles and turn of the motor and start again , the blower will not work. now I found out coolant is leaking on the passenger side the carpet is real wet. dodge dually 2001
  12. Thanks guys , was a lose starter cable,
  13. Turned engine off and 20 minutes later he won't start. Batteries good everything works, when I turn the key nothing.no klick ,don't turn over, nothing. any advice?? never had problems. 2001 Dually
  14. turn on my heater an the A/C is still runningany suggestion
  15. someone running 265-75-16 on a 2001 dually?right now i have 235-85-16.
