eaglesilas
Everything posted by eaglesilas
  1. thanks,found one an eabay for 45,
  2. Replaced my broken manuel Mirrors with heated/electric Mirrors. The electric works fine , how works the heated part? The plugs was already in the door, the switch I bought on ebay. 2001 -3500 Dually
  3. My head light won't shut off , only head lights not the tail light or cab lights, and my high beam staying on, and the blue light comes on in the inside. I have to pull the fuse to shut them off but only one fuse not both.
  4. I think found the short, my side maker lights on the dually fender on the left side . lights are working now for 2weeks.
  5. that's the writing on the cover park lamp
  6. thank no spare tire, It's the park lamp fuse
  7. I have no tail lights, dash lights, marker lights. Only my headlights are working .The fuse blows after 1 minute I turn the lights on. Some advice ,where to start to check
  8. Thanks Guys , the switch was bad.
  9. Was pumping gas and my lights shut off. Turned the switch off and on, no lights only headlights.no tail, no side marker , no cluster lights , inside lights working . checked fuses, all good. Turn and brake lights working.
  10. Disconnected the heater core for now, need a new one. was not the resister, was the blower motor. put a new one in. now my A/C works. Thanks guys.
  11. My blower works only in the morning , when I drive 10-15 miles and turn of the motor and start again , the blower will not work. now I found out coolant is leaking on the passenger side the carpet is real wet. dodge dually 2001
  12. Thanks guys , was a lose starter cable,
  13. Turned engine off and 20 minutes later he won't start. Batteries good everything works, when I turn the key nothing.no klick ,don't turn over, nothing. any advice?? never had problems. 2001 Dually
  14. turn on my heater an the A/C is still runningany suggestion
  15. someone running 265-75-16 on a 2001 dually?right now i have 235-85-16.
  16. will 2011 dually rims fit 2001 dually
  17. Bulbs 9007,and the wiring are good,no damage.
  18. A while ago I hit a deer,my Right headlight got busted. I replaced the light and bulb.The high beam light came on and wound not go off of,driving lights and high beams stay on at the same time.I have checked the fuse and they are all good the high beam light does not go off stays on .Does anyone know what the problem could be.I would appreciate it if some one could help me .thanks
  19. thanks for your help.my A/C is working.
  20. Freon is gone.the condensor is cracked
  21. How do I open the release collar ,do I need to have a special tool , recieved my ac condensor today or purchace a new release collar.Thank You
  22. Have to change my ac condensor .some good ideas
