JimRAM
  1. How long to do these three things? How much skill is required. I've never worked on a diesel but did swap an engine out in a Ford Windstar a few months back.
  2. Any easy way to check if VP44 is working? How about a check for the lift pump? Maybe crack a line open a little? --- Update to the previous post... stodg73 said "First off, the APPS may need to be reset. So try that first." How do I reset this?
  3. Q: have you installed that elbow with the set screw?A: Not sure what you mean. Is this a recall situation? Or does this elbow assembly go bad?
  4. My 1998 Dodge RAM 2500 Truck just stopped dead in the street and won't even try and start. IT has a 5.9 L inline 6 cylinder, 24 valve Cummins diesel engine. I hooked up an OBD II and got the following error codes listed below. The forum here has testing procedures but the first requires the engine be running (it won't start) and the other require a DRBIII scan tool (expensive). I'm just trying to get this running again without major expense. Any suggestions on where to start without the DRBIII? I can check wiring as indicated. Do the combined codes point to a specific item that needs replacing (the fuel injection pump?) with certainty? One thing I looked as said erasing the codes with the OBDII may allow it to start and run. I'm hesitant to do this since it appears some onter information may need to be read by the DRBIII if I have to take this to a shop. Any thoughts or recommendations??P0121 - Accelerator Position Sensor Volts Do Not Agree With Idle Validation Signal P0234 - Turbo Boost Limit Exceeded. Problem detected in turbocharger wastegate. P0253 - Fuel Injection Pump Fuel Valve Open Circuit. Problem sensed with fuel circuit internal to fuel injection pump. P1688 - Internal Fuel Injection Pump Controller Failure. Internal problem within the fuel injection pump. Low power, engine derated, or engine stops.P1689 - No Communication Between ECM and Injection Pump Module. Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.Thanks! JimRAM
