Truck runs fine for about 20 miles, 70mph, 2200rpm air on/off no difference. Coolant temp normal, oil pressure normal. Injectors testing good, no oil or coolant consumption/loss. No boost leaks with soap test. Truck does not smoke at start and only light black smoke when getting into it. After around 20 miles at highway speed all the sudden a trail of white/blue smoke from exhaust and the truck runs normal. I can make it stop by letting off the throttle or pushing it harder, but smoke returns after pedal is returned to normal cruise. After I exit the highway it quits smoking at speed less than 60. I'm about to drop a grenade down the intake...
