Cparks93
Everything posted by Cparks93
  1. Okay thank you all, I’m going to do some further investigation this evening when I get off work.
  2. Yes, it will loose prime.. but I do keep it nose down, at least until I fix that issue. Fuel pressure is above 12psi when cranking. But that is pre vp Will the ecm failure cause a no start? Because I am getting fuel to the vp, but I haven’t checked for fuel at the injectors. Forgot to mention all battery connections are clean as well..
  3. It used to, now I’m not getting a WTS at all. I let it sit all night and it came on, but still would not fire.
  4. I was hoping no one said ecm batteries are topped off and it turns over great... just won’t fire..
  5. Thank you, I will try this tomorrow So the battery temp sensor will cause a no start??
  6. So my daily finally left me stranded. For starters my WTS has always been sluggish to come on when starting the truck. It would not start until WTS light came on. Would crank and crank unless I waited for light. I figured it was a good habit anyways. On my way to work Saturday I noticed my headlights were dimming on and off, pretty abnormal because ambient temp was mid 40s and truck started like normal. After getting to work, I drove the truck 5 to 6 times to get tools with no problems at all. Finally getting geared up to go home, wait for WTS, light comes on, so I crank and get nothing. Now have no WTS and no start. Fuel pressure is at 18lbs. Code reader pulled 4 codes p0500 P1693 p1492 And one more I cannot remember off the top of my head. I will rescan it tomorrow. Anyone have any insight?
