rockbarn
  1. I found my leak on the banjo bolt that goes into the lift pump. We must gave dropped one of the gaskets that goes against the pump when we were putting it back on. Couldn't find it until it was dark and shined a flashlight, we saw the diesel spray in front of the light when we turned the truck back off. Thanks for the help guys.
  2. I just replaced my injection pump and lift pump. I put a factory replacement raptor lift pump on. After bleeding all the lines the truck will start and run fine. Once you turn the truck off it will start and run for 5-10 second and shut off. After that it will not start back until you bleed the injectors again. Please help.
