Hsmtrans
  1. @Mopar1973Man what’s the steps for ground issues?
  2. I don’t think it’s the alternator I unplugged it and pulled the fuse and no change @Mopar1973Man
  3. Ok I’ll have to grab a multimeter only have a power probe I can’t seem to find what I need. Can you lead me in the direction of where I can get what i need? Part store Home Depot etc the one they have here at the shop doesn’t seem to go low enough at all this is what they have https://hc-cargo.com/files/billeder/ecom/products/fg_annex/DK055196.pdf
  4. Dumb question, best way to check ac noice?
  5. Have a 2001 dodge nv4500 I’m having issues once the gauge starts to move and truck warms up I’m having a cuttting out issue around 18-2200 rpm it’ll cut out like it’s banging off the rev limiter have some whiteish blue smoke and you can floor it and it goes away. Ive replaced the. Injection pump,lift pump with a air dog 150, injectors, turbo, cam sensor. Tpps, map sensor, IAT sensor, coolaint temp sensor, fuel lresure is 18 at idle 14 at WOT. Funny thing is if you drive the truck like a jack *** it doesn’t mess up but if you drive it normal it messes up every time. Ecm???
