BIGMIKE
Everything posted by BIGMIKE
  1. Stock,old one is fine ....eliminated issue
  2. 246 ON THIS ONE New lift pump ...still doesn't explain the bleedback
  3. Got 216,253,1693,251,252,1688,0113 all from ecu Ive had it in the garage only using it to pick up new sleds. I did alot of the tests with no luck so i just wanna make sure its a vp before i buy one. Who sells the best ones??
  4. check codes tonight ....14 psi at idle off the banjo fitting
  5. truck 018.MOV truck 018.MOV 2002 6SPD ....pulling on highway truck died ....restarted after about 20 minutes but would only pull about 1300 rpm at most -idles great but if I don't start it everyday I have to bleed the lines to get er going....wont rev past 1300 at best ,just stutters and white smoke ???...seems like a vp44 death
