jttrucker
  1. Hey guys, Ive got a question about my 01 dodge concerning my heater. I live in Big Piney Wyoming (Icebox of the nation) no kidding, we have the coldest on average temps anywhere in the US. We see sub sub zero temps here and while traveling for work as a pipeliner I get into N. Dakota as well. My 01 is probably like everyone elses, it does not like to warm up in these extreme conditions. Everything works fine, thermostat, blend door, core ect. and I also use a winter front. Have any of you used a 12v heater or another alternative to help you stay warm in your 2nd gen? Any ideas. My heated seats help lol but while my backside is warm my hands are freezing lol. I cant drive and sit on my hands LOL. Any ideas? Im open, Thanks
  2. well it happened 300 miles from home LOL, The VP$$ died. I bought a new one from 2nd wind performance in Casper for $1100 and had Jay Moore at Moores Heavy Equipment install it for $400. hope it runs for awhile before doing that again. Thanks for all your help guys!!!
  3. My buddy also a rig welder just bought two 2013 dodges and he put rockstars on both of them, so he put one set of alcoas on his 2005 and sold the others w/tires to me for a grand. His 2005 was exactly the same and he checked it out because he was concerned about his. He found out that you only need 1x the diameter of the stud of threads. I endend up with 7/8 of an inch as he did. He is currently in North Dakota and if you have not been in north dakota on a right away you aint been on a bad road. He has not had an issue with them coming loose. Im gonna keep an eye on them, and so will everyone else LOL. It looks bad A$$!!!! I found this all out after I posted the question because I could not get hold of him. But thank you for the response, I appreciate it. Im hopeing my buddy buys anothe new one lol Im gonna kype those wheels too !! thanks guys
  4. Ya I posted on the other forum too, I need a answer asap, I bought a brand new set of tires and wheels off of a 2013 dually (alcoa wheels) I want to put them on a 2001 dually. I only paid $1000 for the whole set. I want to know if anyone has done this. The alcoa wheels are thicker. The dealer said they will work with my lugnuts. My lug nut is flush with the end of the stud and the stud does not have threads on the last 1/4 inch. Is this ok? I dont want to have to change all the studs. anyone else?
  5. Well, Im gonna be working close to home for a bit so Im just gonna see what happens, my fuel pressure is about 19-20 idle 14-15 WOT and still have not seen white smoke. If it goes, it goes most all of you have been there, so I guess my turn is comeing around LOL. I guess it is what it is when it comes to the VP44.
  6. My 01 is over 12000lbs all the time, it is a pipeline welding rig so I never unload it. I just had the trans rebuilt by western trans in Idaho Falls Id. I really didnt have anything wrong with mine but it has 136000 on it and I am in very rual areas and just decided it was time just in case. I could of went with the ats or bdi and spent alot more but I take care of my trans and change the oil (pan service) every other oil change. I had them go completely through it and do a shift kit, and other valve body work, tripple disk convertor and heaver OD springs and all new coponents. I spent $3000 instead of $6000 but I did not need a trans that could handle 1000hp. I dont drive the truck like a camaro, I have a 69 swb chevy that I can hot rod. So I didnt have a billet shaft put in it but again I dont drive it hard. I think it all has to do in how you drive it what you tow and how well you take care of it. My uncles 01 went 250k on the stock 47re . Im plenty happy with mine, it shifts right now, no slipping into next gear and the TC locks right up and does not lock and unlock all the time as they do stock. I am real happy with mine and it didnt cost $6000
  7. Alright guys, I noticed if I dont let it sit for a bit and warm up the tendancy for it to have the dead pedal is more likley? I am going to have my mechanic try and pull codes again. He uses a Snap-On scanner and is sure if it is throwing codes it will retrieve them. Im going on a little trip with it today to take awelding test and Ill be back this afternoon, Ill have him try again. I tried to get them with the key trick and got nothing agin yesterday and am positive there is no white smoke at all.
  8. NO white smoke, checkin codes by turnin kew off and on 3 times and had a local mechanic check it and he also said there are no codes?
  9. Fuel pressure is up around 20 at idle, drops to 15-16 when I get on it. No codes though. I did have a 0216 code from when my lift pump went out over a year ago but it cleared and has never came back. No codes at all? It stopped doing it for awhile but started doing it again. After I shut it off and start it again (sometimes more than once) its fine. Any suggestions on where to start without codes. Ive searched the forum , alot of dead pedal issues but they have codes.
  10. You all do what you think is safe while welding on your truck but the only thing I would recomend is grounding close to your work, dont weld through bearings, engine and such. Basicly common sence. I weld on the back of my truck all day every day up to 300 amps welding pipe to code and Ive never had an issue and dont know anyone who has ever had an issue. Rig welders dont have time to unhook the batteries. The only time Ive ever seen an issue is in the case of bump starting the truck with the welder. It works on older rigs but I watched a guy on a project fry everything in and on his powerjoke doing this LOL. Who cares it was just a powerjoke and obviously no common sence. I have welded the exhaust, bumpers tool boxes, frames, hitches ect with no problems. Alot of guys run a ground strap off their beds that touch the ground when stopped but basiclly this is only for static electricity, so they discharge themselves before entering a live area.
  11. Just changed mine too, it didnt look that bad but it was coming apart . Hwy 93 lol spent many a late night truckin on that road, Hope the coop at hollister is closed!! Jackpot would be a good place to get stuck.
  12. I was wondering WTH? I had to go back to read my original post to make sure I specified I just built the trans LOL. GOTCHA! anyway Im just looking for mild power upgrade, thats why I was thinking about the edge EZ.
  13. Anyone running the Air Dog 100? If so what is your psi? Does anyone know what acceptible psi is with the AD100? How about adjustment with the ball and spring????? Need some explanation? Im runnin 15psi at idle and about 12 at wot, according to my isspro guage. I do have the dreaded 0216 code so im trying to narrow things down before I buy the VP$$.
  14. well Im gonna get it to Lance Schupe over at pocetello, he is the diesel mechanics proffesor at the colledge over there and does real good work with no BS. He moonlights after class lol. Anyway he just built an engine for a buddy of mine who I weld pipe with and his new engine is problem free and gettin the $#!+ beat out of it on a pipeline rightaway in North Dakota. I think Ive done all I can do so Im Gonna let him take a stab at it and if it needs rebuilt well it is what it is. Thanks for all the help though fellas, I really appreciate it.
  15. Alright guys, I had to get my 01 a new trans, so I went with the whole deal 3 disk TC Jam Pac valve body bla bla bla $4500!!! Got to say the stock tranny held up well even though my truck is 12600lbs. So with that said, Im thinking of adding a chip, get a little more out of the old girl. Nothing serious just a little more hp would be nice since the trans can hold it now. Ive added the S&B cold air and the AD100, so a chip is next. I have looked into the edge ez chip and want some input. Also the intake elbows, do they actually help or do anything? let me know, Thanks
