Johnny Corvette
  1. My clutch never goes soft like this. Really! This is the first time something like this has ever happened.
  2. 2001 Ram 2500 quad 4x2, 24 valve turbo 5 speed.Suddenly clutch started going soft (doesn't engage fully, hard to shift into gear) if depressed for prolong period or if engaged several times in a row. Strangely it recovers and works fine within a few minutes. I am guessing slave/master cylinder issue - but why does it recover and work fine? Air in the line? It drives just fine otherwise and clutch and gears work great as long as I lay off the clutch as much as possible (coast to stops put in neutral, etc.). Maybe this is common but, anytime I had clutch problems in past with cars it was a slow permanent process - no recovery. Ideas out there? Hate to crack open housing and buy parts needlessly. Thanks! PS - looks like a great forum! Had the truck only 1 year and have had almost no problems. Used mainly as a work truck.
