JP24valve
  1. I used ether when I had 3 lines with fuel, but it still dies almost immediately. I did see air bubbles coming out of 1 and 3 when I used ether
  2. Really good amount coming from 2,4,5 the lift pump is supplying the pump with plenty of fuel
  3. It won't fire at all unless its given ether but it dies immediately. I'm getting fuel to 2 4, 5. I havent tried 6 but nothing from 1 or 3
  4. I just replaced the injection pump, the fass lift pump is working good, the pump is getting plenty of fuel. But I cant get it to run, it will start with ether but wont stay running. I have primed the pump and bled the filter housing getting the air out. Please help If you can
