the hunter
Everything posted by the hunter
  1. You mean looking up from on the floor. I believe someone on u-tube cut a hole in the bottom to get access to clean the evaporator. I had the evaporator blown out a couple times and the heat was much better. I am thinking this problem is inside now when I think about. I thought there would be more problems like this. Kind of surprised at that. I am moving to Florida. Just need cooling there. Thanks so much.
  2. Why is my heater blocking coolant flow? Had it blown out two times but still blocks and does not heat the inside of the truck. Any ideas?
  3. Can you email me the letter if you still have it? I did not receive one. Thanks. The Hunter hntrthmsdudley@gmail.com
  4. Not heard of or experienced that yet. Have an 06 2500 as well
  5. I hear it sometimes when the truck shifts to a second gear. And sometimes when shifting into reverse. Not every time, intermitent. I want to think it maybe a u-joint.
  6. Most times when shifting into reverse I am hearing a clicking sound. Any experience with this problem? I want to get it taken care of before something happens. Thanks.:banghead:
  7. Who makes a good code reader? And what has been your experience with it, if any? Walmart carries which Manuf./Model. Thanks all. Very much appreciated. the hunter
  8. This is going to sound dumb. Will error codes display in the odometer if I have no apparent problems? Thanks mopar man. the hunter
  9. Are you refering to the Edge controller? Thanks.:banghead:
  10. This sounds very interesting. I have the company web address and will contact them for any testing that has been done with and without this additive. Thanks for sharing your experience. the hunter:ahhh:ha
