Madmaxxjim
Everything posted by Madmaxxjim
  1. Thanks Everyone! I will look to see if there is a port. The previous owner did the swap and I did look at the block behind the starter and didn't notice a port but I will look closer. How do I tell the year of the block? It has no numbers cast into the block where the 53 numbers are usually located. The only cast numbers I found are 2BF on the driver side front of the block above where the 53 usually is. Thanks again!
  2. Hey Everyone! My 2000 3500 has a block with no crank position sensor port behind the starter. I just bought this truck. The previous owner or someone put an external crank tone ring on the front of the balancer with a home made cheezy bracket that holds the crank position sensor bolted to the front oil pan bolts. The truck runs ok but not as good as my other 2000 cummins. I think the crank sensor timing may be off, and it sounds like I have an injector knock. Is there an ECM I can get that eliminates the crank sensor? Someone also told me that I can wire the cam sensor and crank sensor together to fix this. If not should I convert it to the P7100 pump? This is going to be a work truck for the ranch and just need it to be reliable. Thanks!
