cltdba
  1. I tried that as well. It made no difference for me.
  2. The resistor is only used during troubleshooting I believe. At least that's what I've gathered. It may be as you suggested, that the scan tools have a resistor built in. <shrug> For my truck, I think the problem lies with the TIPM. According to all of the diagrams I've looked at, everything related to the diagnostic port and the ECM runs through the TIPM. So if I'm not getting any (or enough) voltage for the scan tool to read or if the "handshake" isn't correct then perhaps the TIPM is failing. It's also a circuit board/electronic device. What year is your truck?
  3. From radio shack. You take the resistor and go from Pin 4 to Pin 7 and measure the voltage between the two with the resister in place. (Let me add the "I think" caveat! hehe ) http://www.ross-tech.com/***-com/aftermarket-radio.html
  4. Went to another friends shop and used his Alldata (and some other software) to get wiring diagrams. It appears pins 7 and 12 are not used which explains no power on those. (These are the K and C lines for use with ISO-9141-2.) I located pins 6 and 14 at the TIPM and verified continuity. No breaks in the wire from the OBD2 to the TIPM. (These connect at connector C on the TIPM.) I ran out of time and wasn't able to ohm from TIPM to the ECM, but at least I know which wires I need to look at. If the wiring is good from TIPM to ECM then I guess I'll try replacing the TIPM. Not really sure what else to check? I need to find my own copy of Alldata so I can spend hours looking at the diagrams.Oh, I also tried two more handheld scanners and his $1500 LCD type scanner (forget the name, similiar to Matco Interceptor.) None were able to read. I'm not sure how the Quadzilla Scout II and Matco Interceptor can read. I may even take this thing to another dealership and ask them to diagnose it.
  5. I wish I could say I had this fixed. Unfortunately I just have not had time to dig into this. I've been way to busy working on the race jeep and getting things in order for the next race. The tow rig will just have to wait unfortunately. I'll be sure to come back here and update the thread when I get back to it!
  6. Thanks! I'll be working on this issue again sometime next week. I've saved the image and I'll try to decipher it in my spare time. :D heheh I have a race this weekend and have TONS of work to do on the race Jeep to get it ready for Friday & Saturday.
  7. Still haven't fixed this. I tried replacing the ECM, but it did the same thing. Now I'm leaning towards a problem at the OBD II port. Started researching the port and I "think" I should have voltage on pin 7/K Line when the key is on, but I do not. When I get some more time I plan to start taking the dash apart and tracing wires. I need to do this to fix the floor vent control anyway. It's not working either. The radio is factory, but I wonder if the previous owner had an after market radio in it at some point. I hear that can sometimes cause issues with the OBDII port. If anyone has any knowledge about OBD II please chime in. --------- Pins: 4 = Earth Gnd .859 ohms 5 = Signal gnd .859 ohms 6 = 0 ohms, .68 volts with key on 14 = 0 ohms, .68 volts with key on 16 = 12.5 volts In addition to those pins I have: 7 = 0 ohms, 0 volts (K wire/Diagnostic line?) 9 = 0 ohms, 0 volts 12 = 0 ohms, 0 volts 15 = 0 ohms, 0 volts
  8. No chrome/stainless exhaust for me! :P I want it to stay dark underneath and white on the exterior. FTE was actually my first choice up until I came across the prices at TV diesel. I was going to get their 5" kit. I didn't see a 4" kit on their site. I'll give Walt a call and check the price and see if he has any handy bolt on hangers rather than the weld-on kind. --edit-- was going to upload a pic of my truck, but it seems the editor isn't mac friendly. http://forum.mopar1973man.com/image/jpeg;base64,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
  9. Thanks everyone for your help! I feel the 4" kit is the way to go. Now where to buy it? I'm leaning towards TV diesel. (Found out about them from a post here on this forum) They seem to have the best price around and it's a Diamond Eye kit. I like the DE kit because of the u-bolt brackets with hangers. I have yet to wire 220 to my shop so I can't use my welder and this would make things easier. TV Diesel Diamond Eye 4" Aluminized Kit with Muffler And I'll be ditching the u-bolt clamps and going with some of the EZ seal band clamps. Those seem to do a better job and make things easier if i want to change it up later down the road. As far as installation, obviously I would put the cat just after the downpipe. Would you put the muffler directly after the cat or put pipe in between it and the cat?
  10. Excellent thread! This explains why my truck feels laggy without the cat. With the cat my VE percentage is likely lessened, but my "light to light" response is better. In theory, if I'm in the city and have the cat on, I should save fuel because the truck won't need to supply as much fuel to build boost to get the truck moving. As for increasing the exhaust size...Assuming my math is correct, the 4" exhaust is way bigger than the turbo's exhaust outlet, so there shouldn't be any flow issues. There's not really any chance for an overspeed condition, even with the cat on. The only valid point for upgrade to a 5" that I can see is if I were running a larger turbo. I don't know the exact turbo in my truck, but I'm pretty sure it's not a VG. I assume HY35? Anyways, even if it were a VG it's not going to be fully open most of the time so 4" would still be sufficient. I think I'm going to go for the 4" exhaust so I can experiment with the cat and how it affects EGTs. It's also a bit cheaper than the 5". If at some point I find the exhaust is somehow limiting me from creating more power then I can spend the money on the 5" I guess. --- Update to the previous post... So what's your opinion on 4" vs 5" on a stock truck? I will be adding the smarty jr and will likely run it on 40 HP while towing and 70HP unloaded. (Having some issues with reading the ECM, but once I get that fixed I'll be buying the smarty.) Might even opt for a SR or SSR. Still more research to do on each.
  11. Now that makes a lot of sense! Now we just need a Holset engineer to chime in!
  12. I think the whole point of the back pressure debacle is related to the amount of time it takes to build spool. More back-pressure = faster spool? I'm assuming that's why the truck feels more responsive on take-off with the cat in-line. At WOT I imagine having an unrestricted exhaust would be more beneficial. However, I know nadda dang thing about anything of this and am just guessing. :P
  13. Thanks again everyone!
  14. There's no such thing as a hijacked thread in my opinion. If something I posted causes more questions then that means I probably didn't think of everything. All of it is good info. Between truck and trailer I'm only averaging about 12-13k. On occasion I will hit the 20K mark but it's rare. I haven't installed my EGT probe yet. I've got 1,000 more miles before the warranty runs out and I've been avoiding it until then. Anyone still have the cat on that can speak to EGTs?What about the "back pressure" bit, anyone know anything?
  15. That's kind've how I feel about the 5", but everyone raves about it. Perhaps it's that bigger is better mentality? In my 2007, I have plenty of room for the 5", but I still think it's overkill. But then I don't want to buy a new 4" kit only to later upgrade it to 5".My current setup is 4" aftermarket that was installed by previous owner. It's falling to pieces and needs to be replaced. Seems going back with 4" gives me the most options. I suppose if at some point I decide to make tons of power out of this truck, I could upgrade to 5". I don't see that being the route I take anytime soon though. I hate the drone I have now so I'm definitely contemplating a resonator or leaving the cat in place. Was thinking about doing a 4" kit with muffler and leaving my cat in place. Also thought about doing a 4" kit, removing the cat and adding 30" FTE resonator/muffler. But before I decide on any route to go I'd like to understand back pressure and how it affects a diesel engine.
