OldSmokey
  1. Thanks to everyone for the replies, I have a Snap On Modus as my scanner. The truck was an automatic when i got it, I swapped a 5 speed in but still have the HY35 with the wastegate J-Hooked shut.
  2. Hello everyone, a while back I installed a bd boost fooler along with a set of RV275 injectors. I installed a boost gauge before this just to see the difference, if any before and after this was done. My truck would build 24ish pounds on a hard pull, same with a trailer behind it. No change in boost after injectors or fooler. I had my scanner hooked up yesterday playing around and noticed my ECM was seeing 14lbs at idle, and when my truck was actually making 20lbs the ECM would show 34lbs. Shouldn't that be setting an overboost code? Was just curious if this was normal with the foolers?
