porter
  1. When replacing the apps on a 2002 once installed does the apps need to be adjusted?Thanks in advance for your help!
  2. Help! I am getting a dead pedal every 20 minutes or so during driving on a 2002 Cummins only when the outside temps are above 70 degrees and the truck is really hot. When the outside temp is below 70 degrees the truck runs fine. I've reset the APPS just like I've read on this forum and I've cleaned the sensors. I am not getting in check engine lights at all. Thanks in advance for any help!
