hopakco
Everything posted by hopakco
  1. Anyone run Amalgamated's diesel additives? Too bad they were not included in the tests.
  2. Thanks - you mean like for corrosion? And would you please translate "MOD". I did find a green with tan stripe which someone suggested might be the correct ground. And there is also a plain light green besides the yellowish one.
  3. I have the violet with white stripe connected to the light green (actually yellowish-green). Both High & low beams light up but when I release the lever (after changing to high beam) there is an overall dimming negating any advantage of the double connection. Can't figure what's up - it used to work ok. (This on a late 02)
