barknan49
Everything posted by barknan49
  1. thanks all for the warm welcome and yes I am from the finger lakes area
  2. I had the same problem and it was the rear speed sensor that was bad . It was still under warrenty so the shop fixed it so I know no more about it than that:shrug:
  3. Hi I have been on the site for about two weeks and have learned alot already .I look forward to learning more as i red more threads
  4. thanks just wondering if someone had used one and how well they worked sounds like it would be a bad choice . thanks again
  5. has anyone bought a delphi fuel lift pump and if so how did it work and does it have enought pressure ? Thanks
  6. thanks for all the good info Now what does the wastegate do ? I am going to get a repair manual what manual should i get ?
  7. yes I am origanal owner and no the VP has not been replaced no I don't have a fuel pressure gaugeis there a site to fine out how much the parts will be that you said is wrong with my truck?Again thanks for all your help
  8. I did the key trick again and got two more codes they are 216 and 234
  9. Hi new to site and I have a question about the code that came up on my truck it is a 2002. 2500 , 24 valve 5.9 and the code is 1693 what does that mean? I have no idea myself .Thanks for any heip you can give me
