Drc
Everything posted by Drc
  1. I do some research and look at reviews on certain companies with good reviews thanks for the input
  2. Well I knew the truck and the problems it had and I figured the parts I switched out would fix the problems I was kinda rolling the dice buying this truck
  3. When I purchased truck I replaced batteries lift pump and fuel filter after truck sitting for 3 months it fired right up . I figured wasn't getting enough fuel that's why I replaced lift pump weather 56° today started today went to the store came home and went back out 10 mins later it fired right up I seen some remanufactured on rock auto thought about going that route....are they hard to switch out?
  4. Didn't figure that in with purchase....and it's probably not a good idea to buy off a vp from a complete stranger?
  5. I'll check out some utube videos I'm not a mechanic by no means but before I get into anything like that I go to utube and take pictures so it goes back the way I find it
  6. No codes no check engine light....can just the box b replaced? What is psg? And previous owner carried a cooler of water in his truck for that reason or ran water hose over it and it would start
  7. just purchased 1999 dodge 2500 24v ....the truck will start up in the morning but after driving a few miles won't start after turning it off.....belonged to my brother in law it was parked for that reason....i replaced fuel filter both batteries and lift pump behind the fuel filter housing....still nothing....i hit it with a sniff of ether and fired right up.....any help would be greatly appreciated
