Dink
Everything posted by Dink
  1. I just swapped my 2001 to a manual, I had no other PCM. I ran the neutral safety wire through the clutch peddle. the tree pin plug is reverse lights an neutral wire which is the center wire. I had a check engine issue showing several codes to the transmission after searching for a PCM I decided to just fool mine. I removed a sensors and wiring from a 46re and plugged it in. So for so good no check engine light, now to get the smarty to help with the torque management.
