jondgehrke89
Everything posted by jondgehrke89
  1. Ok so for an update to make things even more difficult. I can unplug the crank sensor on the front of the engine and it idles a lot better and and the p0216 code goes away and gets replaced with p0336.
  2. Ok looking for some advice. Ok, so I bought a 99 dodge several months ago. The engine has been swapped out for an 02 engine and computer. The internal tone wheel had been retrofitted to the front of the balancer. For several months the truck had a p1690 code. I did all the checks on this page and everything checked out fine. I finally got it to go away by rotating the tone wheel 180 degrees on the balancer and the code is no more. Worked good for about an hour, than I got a code for p0216 accompanied by the dead pedal. Truck has always had a lopey inconsistent miss at idle. Even after the p1690 code was fixed. I can Hotwire the pump and it idles great nice and smooth with no miss. Looking for a direction to go.
  3. IBMobile, no the tone wheel isn’t like what you have posted in the photo, it bolts to the front of the balancer and has a little spacer someone has made. I can get photos if you would like to see it? To be more clear, the p1690 code was there before I changed the balancer. Just the sensor was very far away from the wheel. I’m going to follow wires and start Ohm’ing things out tonight. Also the p0338 code is now gone but it was replaced with an p0380.
  4. Hello all. I have a 99 dodge, the truck has a 2002 engine that has been installed, after the ‘53’ block died. The truck has a tone wheel mounted to the front of the balancer for the ckp sensor. The truck has the HO vp pump and the computer for the 2002 engine. the issue I’m having is a p1690 and p0338 codes. The only issues the truck seems to have is a miss or stumble at idle that seems to come and go, and high egts. I have recently replaced the balancer as it was coming apart, reset the air gap on the tone ring to the sensor and Cleared codes and they come right back. looking for recommendations on where to go next. truck seems to run decent. mods are a quadzilla adrenaline the old style with the pod, air dog 150, 7x012 injectors, 66/73, built trans and a triple disk.
