DowdsDieselDirect
  1. mine is doing that is seems like only first gear holds out I didn’t know if it was cause I’d the low power and acceleration or the tenant but I think my Speedo is over reading too
  2. So I pulled codes at lunch and ran live data truck threw a code p1690 fuel injection pump ckp senso doesn’t agree with ecm ckp sensor Any tests to fix this the guy I bought it from just replaced the sensor
  3. tranny had all electrical components gone over about 6 months ago tcc solenoid and harness governor solenoid governor sensor gasket under governor block And harness repair but still no power drive it to work today truck tops out at 72 and won’t go past that at 2k
  4. 1999 ram 3500 24v auto low miles 4x4 long bed ext cab has issues shift out of foray into second I can rev up the truck all the way but struggled to shift into 2nd truck also has very low acceleration turbo spools but almost seems like there’s no boost no big leaks or blockages need help
