craiger460
  1. Thanks for all your info! It was very helpful!
  2. Does anyone know if the ambient air temp sensor has anything to do with the operation of the air conditioning system in our trucks or does it just provide an outside temp for the compass/ outside temp display? Also where is the sensor supposed to be located at? My truck did not come with either of those options but I am putting a/c in it and not sure if I need the sensor or not or if it is already there any info on this would be awesome thanks!
  3. Yeah some information of the differences between them would be great I found a company out of Arizona that sells a complete kit for the application I am looking for they claim all the wiring and vacuum is there is just a matter of installing the equipment For some reason that just seems too good to be true
  4. So here is what I have going on- I own a 2001 Dodge Cummins four-wheel-drive 2500 It came from the factory Without air-conditioning. What I want to do is install air conditioning on it. Does anyone have any experience with a project like this? For instance is all the wiring already there in the factory wiring harnesses So all I would have to do is get the components and switches installed And plug everything in it and once the system is charged of course it should work or is there more to it than that Any advice would be greatly appreciated!
  5. 2001 25004x4 5 speed started out truck ia a base model had no Cruise control! I installed a new criuse clockspring and new cruise switches now the cruise light will quickly flash on when I turn it on but won't stay on also I've never had any problem with codes and now I got a code1595 speed control solenoid! Do I have one of theese with a manual trans? I thought the PCM runs the cruise. Any help would be great! Thanjs
