diesel_rob
Everything posted by diesel_rob
  1. Excellent reply thank you for all the info. I just read the W-T ground mod earlier today, I will do it as soon as possible. What type of fuse for the alternator/PCM? Is there a write-up somewhere with more detail on this?
  2. I haven't used the multimeter on the truck yet, other than when I was having issues with the previous set of batteries. There were codes when I was initially starting the truck, the fuel pump circuit was throwing codes, but that's it. I currently have the E-brake light on and the one next to it on. The batteries are out so i don't remember which other indicator is illuminated but it's not major. I haven't looked at the codes recently but my Edge Attitude has a maintenance code readout so I can easily check later today. I busted the terminal that connects to the heater grid wires at the positive terminal of the driver's side battery so I have to fix that, and locate where the firewall ground goes then I will start everything up again and check. Reading some of the posts on here, and checking the wiring diagrams has me wanting to test the AC/DC voltage across my alternator.
  3. I have been restoring a flood truck since last December, the water line was a couple inches into the cab. The vehicle runs and drives, I have since gotten a salvage restored title and it is my daily driver. Through all the many fixes on my vehicle I have had some creeping intermittent boost drop/dead pedal/bucking surging mostly when moving from lower speeds. When I am heavy on the accelerator it seems to be much less apparent. I have put at least 200 hours into the truck this year and have had many components taken out and reattached so anything is fair game when it comes to explaining the issues I am dealing with. The main question I have, and the issue that I am trying to solve is the loss of power on application of the accelerator. What is causing this? Is my VP44 dying, do I have alternator noise, do I have bad grounds or power supply issues? Do I have a dying APPS? I have a thread running on turbodieselregister cataloguing a good chunk of the work I have done on this vehicle, but I will sum it up here because I don’t know if linking to other forums is acceptable. This truck has the following aftermarket modifications, FASS Signature series lift pump (previous owner) Edge Juice w/ Attitude (previous owner) Airdog Draw Straw kit (I did this, to fix the fuel supply issues caused by having the in-tank fuel pump still in line with the lift pump) Jasper Transmission w/ “low stall triple clutch torque converter” (previous owner) Some unknown suspension lift with kyb struts (previous owner) Projects I have tackled in restoring the truck: Rebuilt starter (this was the main thing I had to do get this truck running) Rebuilt hvac box and installed Geno’s garage cabin fresh filter kit. Removed all carpet and sound deadening material Fuel issues (air in fuel line, fuel restrictions From in tank fuel sender) Replaced all u joints Replaced ball joints at knuckles Replaced Vacuum line leaks Cleaned front axle tube and carrier housing I currently have the batteries out and I am navigating some of the wiring with a focus on grounding points. I am using electrical cleaner on all the dirty battery harness elements, it’s not EXCESSIVELY corroded anywhere but there are some spots that don’t look great. I’ve had to do some cutting of wiring at terminal connectors to expose clean copper (in the past). There is a single ground wire that is attached to the firewall above the trans dipstick that I can’t seem to recall where it was attached to before I did the work to this area as part of removing the hvac box. I don’t know if this disconnected ground is contributing to my pedal issues. Is this a PCM case ground of some type? Did the issues with my lift pump and fuel sender cause the start of VP44 failure?
