wwilson1900
  1. It turned out to be MAP sensor and cam position sensor.Both were not reading according to the mechanic I took it to.Thanks for your help.
  2. YIKES, that's what i'm leaning toward though.thanks for your help.
  3. thanks for APPS article.I'm not getting any error codes.
  4. My truck (2000 2500 automatic w/103K) has a bad case of dead pedal.I went by Autozone and had them read the codes and the only one was overboost.I cleared it and none have returned.It also has a fairly new fass ddrp lift pump on it.Once in a while it wil take off like normal for 2 or 3 presses of the accelerator; then just return to the same old dead pedal.Can the APPS be checked with a digital volt meter?Any other ideas? probably VP44?thanks in advance.joek
