Gregjr
Everything posted by Gregjr
  1. I’ll sure check this out, but it may take a few days to get back to it. I’ll let you know what I find. Thanks for all the info!
  2. I do have manual electronics in what used to be an auto truck, but I swapped all electronics with the engine and transmission. So now this is a 6 speed manual with the manual electronics. 🤔
  3. Ok, here is my issue, I recently wrecked my 2002 Ram 2500 H.O. 6 speed and totaled it out. It only has 97,000 miles so I purchased a 1999 3500 with Cummins and an auto tranny to put my motor and transmission in. I have completed the engine and transmission swap and all is well....almost. The cruise will no longer work, the light won’t even come on in the dash. It worked on both trucks before the swap. Here’s another known problem, the 1999 truck had the vacuum actuator under the driver’s side battery for the cc and the 2002 cruise control is all electronic controlled. I used the pcm and ecm from the 2002 so I didn’t hook the vacuum actuator up as the 2002 didn’t use it. Any suggestions would be great. Thanks,
