Gamecocks
Everything posted by Gamecocks
  1. i built a boost tester and tried to use it but it built up so much pressure that it kicked the compressor off, it seemed like it wasnt going thru the turbo bc it only took about 5 seconds to do that. I tightened down the tap screw on the stealth plate and now i get 30psi and power back but still missing that ~5psi or so.....thanks for you help
  2. I was just looking for the thread with what you need but cannot find it. Can you tell me or forward me to that post? thanks
  3. I have a weird problem. I have lost about 10psi of boost, usually around 35psi now im only seeing 25-27psi.... the weird thing is there is less smoke. I dont know what is going on. My lower left IC boot had a small hole in it (not all the way through) i filled it with silicone a while back, i have checked the Edge to MAP connection and its all good. Any ideas what could be going on? The boost seems to be higher in the morning and evenings when the air is cooler.... mid day on level 6 feels and looks like level 4....????Thanks in advance!
