stoney44
  1. I am a retired maintenance mechanic so I am pretty knowledgeable but my question is everybody around here wants $300 to install a vp44 is it that hard or can most people do it.The one thing that concerns me is the keyway falling into the case.Also can the pump gear get off the cam gear while you are doing this.And also is it hard to line up the pump with the keyway.I watched a guy do this on utube and it was a really good video and he shows what to do and not do.
  2. Replacing the vp44 should I replace the cam sensor too as it is easy to get to with the vp44 removed.
  3. Is it time for a new pump and where is the best place to get one.98.5 24 valve 3/4 dodge with five speed.1693 code with 1691 that could only be caused by pump failure right.
