tommyboy
  1. Ill check again were is the comm fuse ? O yeah and my wts light doesn't turn on at all
  2. yea everythings fine i checked the pdc no fuses are blown and when i hooked it up to the scanner it couldnt communicate with computer
  3. my truck is not starting ?!!!!! when i go to start it, it just cranks and cranks im not getting any power to my lift and inj. pump. truck is stock but a couple people told me it was a bad ecm ? went threw the wires they seemed fine noticed im not getting rpms though when its cranking. so i replaced the crank sensor. still not moving. i got the lift pump to run with the relay jumped but plug it back in and it dosent fire up need some help maybe a wire diagram ??or just some expert thoughts !thanks !
