dwd3614
  1. Sorry I mis printed something,I have replaced the lift pump and the VP-44 but still no justice for a poor man,Sorry about the mis print
  2. I have an 01 dually,that I bought from my mother after my dad passed away last year from brain cancer. The truck had sat for about 8 months,and after I had driven it for about 4 months,the lift pump failed on the way home from work,and the truck died and I had to tow it home. I replaced the lift pump,but I still couldnt get it to crank and run, it was getting fuel to all but the #1 cylinder. I checked for trouble code but it didnt display any,because the engine light wasnt on. I bought a lift pump and replaced it. I still cant get it to crank,but I did get some codes this time,they are P-1693,P-1689 @P-0122. Is there something I did wrong or something else wrong with the truck,By the way the truck only has 53,000 miles on it,I'm stumped.
  3. replaced the injector pump,still wont crank,got 3 codes this time,p1693,p1689 @p0122,is there something I need to reset after then new pump is installed or is there more problems?
  4. It has a new lift pump, new fuel filter,tried the error code thing,dont show any,can crack injectors and get fuel to all but #1 cylinder,tries to crank but just dont quite make it. Ran the batteries down trying to crank after a while of cracking injectors and getting fuel everywhere but #1. Bout to pull out what little hair I got left!
  5. It turns over but will not run,tried cracking injectors,will almost start but acts like not enough fuel. any ideas?
  6. Got an 01 dually,replaced the lift pump, still no crank,tried the code display it displayed the p pcu then p done then p ecu then p done but no code inbetween either. Got a $300.00 code scanner on the recomendation of another tech, showed no code stored because check engine light not on. I am stumped as to the problem with my truck
