Rail Pressure Troubleshooting
2500ctd
I like that bike. You can see mine through the cleaner fuel. Lol
This pic is when the truck was down and needed to finish rebuilding the forks since only thing left working was my bicycle which is leaning against the truck
03 Buell Firebolt.
 Understand as well. Truck been running fine last couple days. I dumped the diesel out of containers I used to drain the tank and the last bit of fuel I poured into a dry gallon water jug and there was about 1/2 of whiteish/milky crap on the bottom.  Also the rest of the diesel I checked stayed cloudly. Only bit of diesel that cleared up was in the pitcher that I posted earlier in the thread.  Going back to a bad batch of fuel.  Only thing makes sense to me.
As a last ditch before drastic measures I got one more fca with the cleaned out tank and fresh diesel and it ran fine.  It did need a bit of time to learn again.  Idle want stable at first.  Activating the high idle seemed to make it learn quicker. Im at a loss as to the actual cause.
