Just to pick everyones brain....I just discovered that my a/c clutch engages on every position of the vent selection dial on the dash and only goes off when you turn that dial to off... Ever here of this? know of anything to check for? not an a/c guru at all I never mess with them. but with all the other problems this truck has had I might as well jump in and see if i can fix this too. Any thing I can unhook to make it not work till im ready for it or get it fixed? by the way its a 2001 auto truck. Thanks in advance
seen this over at CF. its 100% normal. the A/C is used to help dry the air.
