replaced all the seals in the pump along with a new psc power steering pump bout 8000 miles agonoticed yesterday a tiny drip on the drive way, wonder what I did wrong, everthing was good and tight, or are these seal manufactured in china?, was a Gould pump kit
  • Replies 8
  • Views 2.5k
Did the shaft have any wear rings on it from the previous seal? They are hit and miss my 02 has 112k on it and the seals have never leaked. I check it regulalry just to make sure.
no it was clean, looked and made sure before buttoning up thanks
Thanks,I am going to tighten it up a tad, I wondered the same thing,but there is a little oilon the vacume pump[where that bushing holds the seal in,] looking from the bottom, do you think the oil could blow onto it and looks like the seal leaks? from the return line?
Yes you'll get that with the fan blowing it around, looks like it's coming from the seal but it's actually just blowing up there. Tighten the fitting and spray it with some carb cleaner then drive it a few days.
drove about 40 miles, parked it, nothing in the drive way, will see I hope:thumbup2:thanks for your help
