Can you use Off-road P7100 pump in a 24 Valve cummins conversion?
What the title asks? Im looking at doing a conversion and am looking at a good deal for an off-road 838 p pump? Can i make this application work somehow? if so, what do i need to know or do? And could i get this to work with an automatic 47re transmission?
Edited by Cumminz
Like said, it depends on the governor.  Plenty of off-road equipment used the same governor setup as in trucks.  Some of the early 12 valves had 838 P7100's.
On the back of the pump, there will be a data tag that specifies the governor type.  Maybe get the seller to snap a pic of it?
Here's my stock 215 pump, notice the "RQV", that's the governor type.
The translation is:
R = Governor
Q = Transverse spring
V = Variable speed governor
400 = Rated minimum speed (idling speed = 1/2 engine speed, engine idle 800RPM)
... = controlled range
1400 = Rated maximum speed (= 1/2 engine speed, engine max speed = 2800RPM)
P = P series pump designation
A = Modification letter
121 = Type code
1 = Suffix
K = Torque matching by characteristic.
Edited by Cowboy
