Posting on this site because many are familiar with hose sizes and what pressures do to floe.  I want to install a back up fuel pump in a small motor home.  Gas...not diesel.  On a small 5.4 trition.  I can work out most of the plumbing but I'm stuck on figuring out how much gas I can get through a certain size line.  I have a gas line much smaller in size that feeds a generator.  Much smaller than gas line to engine under the hood.  Would be great if I could use this small line.
What is it called...figuiring out how much fluid you can a certain size line at so much pressure?
If someone would give me a hint...I could google from there, but don't know what to look up.
Thanks
  • Views 1.5k
