Electrical problem after replacing drivers fender
So I bought an 02 24v knowing it needed some work and drove 40 miles home, then realized it needed a new map sensor because it was in limp mode so replaced the sensor and everything was running fine. The drivers side fender was heavily rusted out and needed replaced, so took the old fender off and took about a month before we could find another fender. Went to install new fender and reattached everything including grounds, went to hook battery's up and the truck went into start mode without the key in the ignition and actually tried to start. Any ideas on what this could be?
  • Replies 2
  • Views 1.4k
The only thing that makes sense is that the PDC is on that fender well, maybe a pinched wire under it????
does/did the truck have an alarm in it???
Bob
