Information Please
   I've started a little project and in need of the out put voltage/cycle frequency mapped at different speeds for the RE47 output shaft speed sensor to the PCM,  the rear axle speed sensor to the ABS controller, or the ABS to the PCM; also the differential size of the truck the info was obtained from.  I know this is a shot in the dark but what the hell.  Thanks
