Good front adjustable control arms?
Looking to replace control arms on a couple old 2nd gens. I am curious to know what experiences you guys have had with different aftermarket control arms? Good / bad or any advice you think a guy should know while searching. The trucks are staying stock so no lifts no big tires still daily driven work trucks. My thinking is if i am going to replace them i might as well get something better then stock. Also one of the trucks the excentric hole is wallowed out a bit from being run lose at some point. Its probably not the best to expect it to adjust correctly anymore. That one is mostly why i think i could get away with adjustable control arms. Otherwise non adjustable ones would work for the other truck that don't have that problem.
