Cruise won’t turn off
On 9/2/2020 at 6:34 AM, Mopar1973Man said:
I don't think its possible.
You'll have to most likely pull the entire dash. The harness connector is down on the driver side. Once this and the ground wire in the driver side kick panel you should be able to pull it out. Just remember to remove the bottom steel bracket on the dash so it lifts off the steering column. Wiring wise everything unplugs. Now once the dash is out you'll see what is holding the fuse panel better. I've never could figure that one out being I've got huge hands and really tough being up-side-down under the dash trying to get pass all the wiring.
So I can unhook the grounds and main harness from the dash? Or undo the harness from the body and pull with the dash?
