How To Display Engine Hours On The Odometer
What Is Needed
  • Ignition Keys
Procedure
This is an easy process to check the total hours on the engine. First off insert your ignition key and turn the key on but do not start. Quickly pressed and hold the trip button until the odometer display switches over to displaying hours. You'll know that the hours are being displayed. The odometer display shows the Hr prefix for the hour number displayed.
Purpose
If you happen to be using your truck in a manner that has extended idle times or possible PTO usage or using an 12-volt electric winch where the truck is idling for an extended period you can base your maintenance off the hour meter instead of the odometer which will not account for extended idling times.
Full Article with video for subscribing members
View full Cummins article
  • Views 1.7k
